parakey
1,367
226
Juz wanna ask is driveshaft is a common thing to rosak?
Driving my car few day and hear some weird noise while going through rough surface or those zebra yellow line.
driver side have sound kak kak kak kak kak while going through the yellow line.
The crack is likely the source of your noise
Reactions: Izso
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
Actually, if can grind down to bare metal, see where the rust spread, need some rust prevention paint also, just spray inside, weldable paint too. If not, just cut and match, bend some good steel and weld.
parakey
1,367
226
KHNG940413
668
56
johor bahru
Wira update
Done redrill the old hole and make a new tread pattern for the nut.
And went back ti kedai potong buy 2 rear crossmemver nut.
Juz to let someone who is going to chg the nut.
Front croessmember nut is long rear is short one. Because I don't know and go and buy the long one and cannot fit to to rear. Need to add washer to use until I bought the correct one and replace it. Hahahahahahha
So next thing is going to source a front frame & survey price for fitting it.
KHNG940413
668
56
johor bahru
Is been a long time
Since my wira for is running fine now so I juz jump to my another car.
My Honda Jazz.
Was planning to mild mod abit ever since I bought the car.
But things didn't went what I had plan. So I had keep it stock for a long time. Only swap the original grill to a Mugen grill that was same as Japan Mugen spec & quad Led fog light (the old one broke so have chance to change the fog like I always wanted.
This is a 2014 second hand full spec car.
Bought it on 2018 and owning for 2 year now.
Inside my 2 year of ownership the car didn't have any issue. Juz regular oil change.
Juz few day ago replace a alternator belt that is worn out.
And what you see the picture is a header I always wanted to chnage. My friend planning to sell his City Gm6.5 to a Golf(rich guy,hahaha) so he ask he do I want to swap with my original header. Since both car same engine so is juz pnp only.
After changing it of course the car didn't few faster lahh. But....the jerkingness a lot speed is gone. And the car accelerate more linear.
So quite happy for the result. Was planning to swap the cat pipe also. The pipe that connect to the header one.
Dear all Senior,
Good day to all of you,
Anyone can recommend me, which shop know how to exchange Wira engine to Mitsubishi engine very well.
I got one VR4 2.0 Turbo engine, thinking to find a workshop to do this engine changing......
Area in Petaling Jaya, Damansara.
Thanks for your kind info~ pls reply my post if u know~
