Juz wanna ask is driveshaft is a common thing to rosak?
Driving my car few day and hear some weird noise while going through rough surface or those zebra yellow line.
driver side have sound kak kak kak kak kak while going through the yellow line. At 1st I tot was my batang bonet. So I didn't care much until today i got time to check my car and ask my colleage he say might be driveshaft sound. So we try to goyang the sfaft behind the wheel and there was some sound.
The left side is ok,when I shake it didn't move at all. The right side can be shake abit but didn't affect driving on highway. Not like last time haven't change the car on 90km/h start to padel shake.
Drive shaft damage usually start by making noise on full steering turn, then will be louder and louder until when slight turn make noise better change.....
KHNG940413
668
56
johor bahru
Now turning anything didn't have any noise. Juz when going through yellow line & rough surface above 50km/h the sound come up. Other than that drive fine.
wahhh.....I haven't use for 1 year and start got sound weh.....
Haiyaaaa........also a common for wira? Lagi haiyaaaaa
Not a common problem for wira lah..
Common problem for all old cars.
Better check properly before changing.
On my Waja, no sound at all but vibrate at certain speed under load. When i release gas pedal, no vibration.
Yes u can change one side only. That is, if u did not discover that the other side oso got torn rubber boot...hihihi.
I just diy change my BLM subframe (too bad i did not take any picture to share ) mount only to also see the rear axle bush oso penyek while laying under the car.
lsm1991
1,469
185
boss, i think its best you describe the sound...
clicking? rattling? creaking?
the sound tells alot
sweelt
Nov 6, 2016
2,306
248
yours probably metal knock metal sound. Like taikor described above. bushes, mounting..etc
KHNG940413
668
56
johor bahru
If next time I chg might consider to find a silicon driveshaft cover for extra protection.
Wah dun scare me like that lahhh...Hahahahahaha
The sound only come out from driver side only.
minibeany
598
102
543
sort of like metal hitting sound. Is like a metal sheet hitting another metal thing sound. tak tak tak tak metal sound
yup,is like a metal sound. going smooth road didn't make any noise. Juz going through rough surface the sound start to come up.
do you have a stabiliser bar in the engine bay? it happened to me when my mounting gone bad.
Right off the factory floor, the Honda CR-Z could be labeled quite a decent hot hatch. It might not be leaving rubber strips on the apexes of corners like its Civic Type-R sibling but it has received some promising reviews from the motoring press.<b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b><b></b>...
