Humble DIY Repairs On My Car
M_Engineer
Jun 2, 2020
28
12
39
First DIY video to diagnose a Check Engine Light with accuracy. More DIY videos to come on this channel “Forged For Speed”. Stay tuned.
❗... New Video Release ...❗
Reactions: TitanRev and Tom
That OBD2 and software - where do you get them from and is it free to use? (software)
My OBD2 bought from Lazada, works well with my HP apps. So far my chery suv CEL, manage to find the fault.....
Reactions: Tom
sweelt
Nov 6, 2016
2,306
248
If can find the fault from obd2 is good and precise.
If no CEL indication, body aching loh...:mad:
M_Engineer
28
12
39
Interestingly sometimes there can be a fault code captured but no CEL indication, I faced that before, not sure why no CEL.
The cool thing with this scanner is you can perform data logging of the sensors that the ECU reads which can point you to the vehicle issue even though no CEL.
My car for example engine knock does not trigger a CEL but I can log the knock sensor activation. If that fails the car got arthritis already haha.
Tom
TIMETOATTACK
Jul 6, 2000
5,562
3,229
good tutorial, pretty sure many modern proton owners would thank you for this
Correct me if i'm wrong, but most obd2 bluetooth dongle should be able to do the same thing, just depends on the App used
I have a generic one like in this video below, works most of the time except for intermittent connection problems
Reactions: vr2turbo
Yup. I am using one of this too.....so far okay......
Reactions: Tom
M_Engineer
28
12
39
Thanks for the kind words sir. I do hope my videos are beneficial to people. The bluetooth scanner hardware acts as the Vehicle Communication Interface (VCI) only. The brain is like you mentioned the application. So technically it will be able to do the same thing if the app is the same. The catch is good apps from developed companies like LAUNCH, AUTEL etc will only work with their proprietary scanners.
Reactions: Tom
lsm1991
1,469
185
I haven’t use that brand before. Can share what functions can it perform?
theres many brands, specially china ones.
its prettymuch the same, end of the day all you are dealing with is just a bunch of signals... the way it manipulates and reads the signals are exactly the same, its the error library you are paying for with the more expensive scanners (i mean aside from obviously the additional stuff you find on the fancy gear). If someone actually spends the time to build the error code library, you prettymuch get the same thing. theres hardly a difference if the idea is just to pull/clear codes. now when it comes to live readings, maybe its just me, but these things seem to be abit sluggish? maybe its the older sluggish ecu, maybe its latency i dont know.
Reactions: M_Engineer and Tom
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
This is okay until a certain level. The 32bit continental ECU of Proton can use this, 16bit cannot. Some pins are unavailable on the send or receiver side, my car cannot set throttle relearn or reset my immobilizer.
Reactions: Tom
Greetings earthlings,
Today I bring you a hot red sexy little thang called a Flesh Red Polo (owner is a colleague of mine and she says the color code is Flesh Red.)
Da story:
Car is more than 1 year old but less than two years old. Have been sent to some auto detalier previously and my colleague feels that its time to give it some pampering again before her wedding.
So off she goes sending the car in for a treatment.
Condition upon arrival is..... WOOT, looks nice in the pic...
