Satria Gti model Brake mod
lsm1991
1,469
185
Who also got money i believe just the matter of time and saving.... ofcause i am looking for idea to cut short letting poeple Cut Throat.
1) function and weekend car
2) i saw people mod before but i lost the contact....
3) i think of EVO 7-9 brembo set but too exp it cost rotor and caliper front and rear RM3000-3500, with R32 RM1k only and same 4pot and 2pot for rear
icic, so you already have the brake kit, that case then year you are pretty much stuck with those. was going to suggest just going evo3 since those are almost direct pnp... now the trouble you have, is it an issue with not being able to find someone to make the adapters? or do you literally not have anyone who can install them mechanism and all? former i can ask around, latter i think none of the fellas i know really wants to do this kind of swap
haha and the evo/subi/typer brembos cost 3k cause they huge and have relatively huge pistons compared to the 32.
minibeany
598
102
543
17 inch rim might affect your turning radius. Make sure u have a real low profile tyres. I read some actually do a bit of roll fender to get more clearance.
Reactions: sweelt
coolman91
224
Offset number are in mm. Normally many OEM offset is around +55 to +45, so say your original is +45 an using +35 offset this rim comes out further 10mm.
Not only offset you have to see the rim design too. If the spokes are on the outer edge then should be okay, some design the spokes are near the middle then even with lower number offset may not clear......
Thanks for the info...... still getting more knowledge about it hahha
coolman91
224
thanks bro...... but maybe when i need i give u a PM
now recovering xD
Yes i know brembos are better and bigger but way higher cost already hahahaha
coolman91
224
Hmmmm...... turning radius why will be affected ?? mind to give somemore advise. ty
fender already roll hahaha thanks for this advise =)
coolman91
224
i think you can make do with 16"..iinm r32 stock wheel are 16"..300mm rotor would be nice for 16"
I scare later purchase a 16inch rim and clearance have issue best go 17 i guessss.....
furthermore 17inch tyres more selections right? hahaha
plan for zentino tyre semi slick
lsm1991
1,469
185
what do u mean by sure to hit ?
meaning offset number higher i will have issue when turning ??
basically theres 2 clearances to take care off
1)radius this refers to the top and bottom clearance, by right marshal is telling you 16" should be fine here since the skylines came with 16's factory
2)the offset/spoke refering to the left or right clearance (where the caliper may hit the rim's spoke at its side. this one, pandai pandailah.... nothing to do with the rim size, just the offset+spoke design
That quote was on the roll fender, meaning with 17" with higher profile tyres, and low offset number, the rims come out further will hit the fender
dear all,
recently i have change and install a front anti roll bar from dsport to my perodua viva 1.0 auto.
i find that now the steering feels heavy.is that normal? :confused:
thanks
