SOHC car - you're just looking at moving your power band here or there only. You won't improve anything much by adjusting the pulley on a stock cam
parakey
1,367
226
i also just ordered a adjustable cam pulley by HKS. its to get ready for the high cam . has anyone experieced any improvement to the acceleration by retarding or advancing the cam timing ?
Before fitting, I would advise you compare it against the timing mark from the original. If possible, take a pic of both side by side for future reference.
Reactions: sanekit
N/A Proton Brudder
May 28, 2018
26
24
ya. i knew that. i mean how dramatically does it affect powerband and power delivery throughout the rpm range when using a mild-agressive camshaft ? retard vs advanced. given i advanced my distributor timing by quite a lot already.
N/A Proton Brudder
May 28, 2018
26
24
Also was facinga problem starting when using an aftermarket tachometer. i needed one bcz the stock 1.3 one doesnt have an rpm meter built onto the cluster guage. whenever i attatch the signal wire to the (-) side of the distributor terminal,the car would'nt start. just cranking. (no spark?). when i remove the connection, the car starts like normal. How do you guys traditionally set your external tachometer ?
The more aggressive your cam, you gain high end but low end suffers. I did Advance timing on my former car, gain low end but high end rough....
sanekit
Dec 9, 2015
1,616
157
why tap at distributor? try check behind your speedo. usually there's rpm wire already in the harness. just need to tap there. or tap from the ecu side.
Changing the cam shaft means you're introducing a change in the lift and duration of the open/close lobe things.. so yes you will get more power with a cam change. The cam pulley does nothing other than shift the powerband around.
sanekit
Dec 9, 2015
1,616
157
Thanks. What colour of the wire should i tap ?otherwise i have to splice one by one until i get an accurate reading on the tacho. i'll update my progress when im free.
i don't know what the color is. you can refer to the pin-out on the location of your rpm wire is, then trace the wire color behind the dash cluster/speedo. tap it there, tap 12v wire from your ignition key, tap lights if any from the signal stalk and ground to body.
Reactions: parakey
N/A Proton Brudder
May 28, 2018
26
24
Update: Hey guys great news! i was able to get the tacho running again + New tires.
I just spliced the signal wire to one of the wires connected to the distributor's 6 pin connector. I just had a guesse and splice one by one. Its the 3 pin hole from 1st facing toward front of engine. My guesse that might have been the signal output wire to the ecu reading from the distributor
And i just got hooked up with a set of Kumho PS31 on my 15" JRD rims. Has anyone had an experieced driving on the PS31 by kumho ? performance to price-wise. How is daily driving handling? Aggressive cornering percormance and in the wet ? It feels like a major upgrade from the Sailun Atrezzos that i rode on previously. Now feels not skidding anyomore when hard braking and cornering above 60+kmh. what are your thought on these tyres ?
Tested these tyres on friend's kelisa. Not bad, handle quite well but did not test them to their limits. However from feedback they are quite good, but not at PS3 or RE003 status, which is actually quite commendable for Kumho tyres and it's pricing. Against your old Sailun tyres sure will be much better......:driver:
N/A Proton Brudder
May 28, 2018
26
24
anyone have opinion on GAB SP Series lowered/performance spring for the wira ? how does it hold in cornering performance and will the spring weaken in a year and lowered summore ? givien my shock abs are new (1+ year old)
i've tried these on the same engine blok:
  1. changed head cylndr 2 times
    skimmed head cylndr
    top overhaul 2 times
    gnrl o.haul
    rcntly..change the radiator fan
and still i got this overheating problem on hill climbing @ traffic jammed..engine BOT running at 0.5 bar..afr on boost 12.+ off at 14.0-15.7..
i can heard some bubbling on the engine just after i shut off it..
what else sud i try?
