Airtrek Turbo (CU2W) Engine (4G63T), tranny and drivetrain swap to Lancer 2008
Mitevo7
1,456
179
I think if you swap to Evo X 4b11t will end up cheaper.
EVO X is my 2nd option, i would opt for Ralliart, mechanically simpler and has a 6th gear for high way cruising.
Yeah but EVO 7-9 you can still find it below 15k, Airtrek turbo is 7k !
Airtrek engine so expensive meh? It's the weakest engine out of the 2nd gen 4G63T so I'd think it should be much cheaper. 9 and 8MR are the expensive ones.
lsm1991
1,469
185
yea bout 7 give or take
Mitevo7
1,456
179
I always look for the most expensive half cut for me to have a high and low bench mark, it's the weakest due to so much has been detuned. I have another option is Evo 7 GTA half cut but its double the price. Not worth if i am going to spend large portion of my cash to fabricate stuffs to make all things work.
lsm1991
1,469
185
k let me be frank...
just bolt on or evo x
if u do die wana install 4g
gen2, look at evo4/5/6/airtrek, forget 7 and up... alot more complicated for a swap.
gen1, your calllah but e3 is cheap these days.
I saw a Ralliart turbo kit for 4b11 on sale in Facebook, rated to 240hp. I think better bolt on that.
Mitevo7
1,456
179
Need to convert the gearbox to manual, and will need LSD to hold the power to the ground. This was one of my options 3 years ago but i found out the manual gearbox conversion is as expensive as a Lancer N/A half cut, i put that idea away.
Ralliart is simpler than Evo X. Evo X got plenty of stocks in MY though but still hella expensive. Realistically speaking, 4G conversion is extremely difficult to do as might involve cutting some body frame, which cutting is needed i will straight say no. My mechanic still checking the Airtrek body and mount to see how difficult it is for this swap. An Airtrek turbo just came in to his shop for oil change and driveshaft shaft, so he took this chance to check it out for me. Stay tuned.
lsm1991
1,469
185
im pretty sure can be made to fit without cutting... but be prepared to keep the car for life. I'll say it again, turbo the bugger or swap in the 2.4+ turbo the bugger....
also... if the lackthereof lsd is a buzzkill for you, the airtrek doesnt have it either (afaik)
**also think i saw a turbo kit for sale... 7k (im sure u can nego)
Mitevo7
1,456
179
I heard you mate, let me satisfy my hunger to know on this mod, even if my mechanic friend thinks it can be done but whether he wants to do it or not is another case. I won't force him to do it if he is not confident.
29,998
Problem with BOT, is the internal may not last.....:driver:
Hi all Sifus,
Need you all advice on my steering problem. My car sterling keep on suave to left while the car on the road.
I have done twice alignment and balancing..my tyres also is new..light accident on bumper only..
please advice..thanks in advance
