Buying a Bmw 330e
DanzEterna
15,911
3,371
www.primeperdanaclub.com
have asked Mr Lee regarding complete 1jz auto conversion
2017 - RM16k
2018 - RM18k
2019 - RM21k....
cant afford to convert la like this.....if manual tranny add another 6-7k.
Ah, Puchong/OKR Lee, his work is legendary. Good stuff. But there are other guys you can go to as well. Pls let me know if you interested. But the main cost is usually the engine. Source the engine and GB yourself, buy the mounts yourself and I'll bring you to my mech who has done several conversions. Might be slightly cheaper assuming you don't go nuts with the mods. Oh and I highly recommend a Links Extreme ECU or something. Don't use piggybacks and complicated setups.
But since yours is a e46, work out that rear chassis crack issue first.
Mitevo7
1,456
179
Never had an issue with rear chassis crack ? What are the symptoms ?
parakey
1,367
226
Just immediately asked my tuner to check below as i am performing FICD and radiator mod, no cracks and everything is tight as virgin.
If not doing track or driving roughly in plantations, I dont think yours will crack that easily. Btw, no need check. If cracked, you can hear it
raining
188
10
kuala lumpur
Of course those R32, s2000, A86 are not Evos, Evos are boring *yawn* cars, Ironically I happen to Own an Evo8MR running on Tomei turbo+ link ECU. So believe me i am more than qualify to comment on Evos. and I know RM per HP cost. :biggrin:
I own 3 out of the 4 cars u mentioned..
Computer-generated image of the RWD Coupe.
Don't dismiss Hyundai as "just another Korean car maker", the Korean company is rolling out its new RWD BH-platform on which the new Coupe will be based on. The model name for the Coupe is not confirmed yet but it is rumored that it will be called the Tiburon.
Just look at those...
