4-2-1? 4-1? Extractors broken down!
those mild steel replacement is ok. better flow than the stock cast iron. the SS headers usually got larger diameter piping and longer header design. you'll suffer a bit at low RPM.
this is from a seller on mudah. he advertised it as racing extractor. u can see the length of the pipes going down is longer than stock.
this one is from another seller. advertised as JASMA extractor. design is almost same as the racing one, but has a shorter pipes.
and this one is your standard besi putih extractor which has a shorter almost stock length piping joints, cheap and cheerful and definitely lighter and better flowing that your stock cast iron. i've used this before on my previous 4g15 auto vdo engine. no complain, does it's job.
actually all those 3 extractor have same dimension..
only material and weld quality different... :biggrin:
LittleWhiteWagon
1,656
187
P.J
about RM700-800?
have to replace because the ori piping having some 'pimples' and maybe some hole some where along the pipe already.
Just get an off the shelf 4-2-1 + 2" pre-made piping that's mandrel bent with a bullet. Some exhaust shops have these.... great way to cut down cost and get proper piping. Hangers all also are made to fit ngam2 for a wira so there's no headache.
Muffler it's your choice of look + sound. Personally I like straight flows any day even if it's a bit louder. Better performance & FC.
S-Flows are super restrictive and FC suffers slightly, but quieter.
parakey
1,367
226
+1
Having question, which alot people said that open pod was`t suitable on automatic transmission.
I have few numbers of friends installed open pod on their automatic myvi, vios, persona, accord, civic and 350z also having good result on performance increase.
Another weird answer from a friend with 350z roadster is better fuel consume after installing a long ram open pod + CAI with heat shield cover.
I`m currently going to do a short ram intake with heat shield cover for my 1.5l automatic...
