Newbee with airtrek T, can run on RON95 ? really need to remap to use ron 95?
badguy
951
2
3,018
hi all sifu here,
i will get my airtrek turbo soon
can i pump RON 95 for this car?
do i need to remap ECU to use ron 95?
as i know after remap HP sure reduce, is ok for me
after remap to use RON 95
can i flood the pedal?
ixeo
4,788
3,080
KL, Malaysia
hi all sifu here,
If you remap the ECU then confirm can use RON 95.
Yes, unless the remap was done badly.
hi all sifu here,
Like what Ixeo said - if the car was remapped or tuned for 95 then yes. Otherwise prepare to pay for 97.
iameternal
67
6
40
hi all sifu here,
wow, how much hp and torque there?
By the way the Ron 95 subsidy is going to be in future, might as well use 97.....lol
badguy
951
2
3,018
What does your manual say on what petrol to use, or listed at petrol fill cover?
My VR engine can run on Petron and BHP Ron95 but not shell....
i havent get the car, coz the car in the spray shop for repainting,
badguy
951
2
3,018
may i know how many liter engine oil for this engine? 4 or 5 liter?
badguy
951
2
3,018
and what is the suitable engine oil for this engine?
0W-40 fully mobil 1 european car formula
ok to use?
marsha1l_v6
666
130
543
Remap ecu is possible, im not sure what are airtrek ecu code, but you can confirm with the tuner beforehand.
I remap my stock evo3 ecu + replace the chip + dyno tune (mainline dyno) about rm7xx. Launch control additional rm50 with wiring.
btw, your aitrek is fwd or awd?
Not sure of airtrek engine oil amount. Hope some owners can reply to this....
arent airtrek 4g63t engine...4 liter should suffice if there is no engine oil cooler.
Dear All,
As mentioned above, i want to know the whether too much negative offset in OEM wheels can cause tire vibrations. Current car is an E46 318ci with stock undercarriage. Wheel hub is still using stock and standard which sits quite inside the fender. Current wheels are OEM 17" with ET37 offset. My mechanic already gave me a preamp that i will experience slight vibration and on-wheel balancing can only reduce it but not cure it completely. As he said, i did feel slight vibrations...
