Preferred Piggyback ECU for 1JZGTE VVTI.
sweelt
Nov 6, 2016
2,306
248
Stock 1jzgte VVTI uses recirculated BOV setup. The HKS SSQV that i had is vent to
atmosphere setup, and since i am still using MAF setup, the vented air will cause the engine to run rich.
Maybe you can get hks ssqv adapter to recirculate the air instead get another bov. Got sell.
But during idling the BOV is closed? Do you mean idle immediately after release throttle?
Mitevo7
1,456
179
1. both Unichip and Emanage have huge support in KL. Both have huge followings.
2. both work. Unichip will need that module. EManage however I'd recommend you go higher end like Ultimate.
3. both will need to splice your original wires so switching to standalone might be messy
Hi Izso,
I am not interested to switch to standalone, wanted a more plug and play type of solutions. Think i am getting the unichip since i had seen more people reviewed that its good things compared to Emanage. Emanage has notorious reputation of being called E-damage.
Thanks,
Ken
Reactions: Izso
Mitevo7
1,456
179
Yes i knew that, therefore later on i will research on ideal positions to mount the SSQV to reduce the use of long hoses.
Thanks,
Ken
Mitevo7
1,456
179
Idle immediately after release throttle, there were few times the engine almost stalled upon releasing pressure.
I had that issue once, but I think my mechanic just did some tuning. Still having my BOV vent out....:driver:
You running 1 bar boost, of course you need special tuning hahaha !
No lah, mine stock boost 0.6 only. Got one time vacuum hose came off, boost at 1 plus bar, idling no issue also, but acceleration very shoik......hhahahhahahhaha
Mitevo7
1,456
179
I think for auto transmission, recirculating BOV is more suitable due to we don't need to lift off throttle to change gears, we are staying constantly on boost. As for manual, dump valve is more relevant.
