Proton owners with coilovers
STR
155
4
18
Cut to the chase, im driving a wira and got myself a pair of coilovers quite some time ago. I was actually warned that coilovers might rattle the interior pieces. Still got them at the end of the day. Yes, it does rattle the interior pieces, especially the door cards. I learned it the hard way.
I just want to know if every car(local and imported) actually goes through this if coilovers are installed in that particular car. I highly doubt this though, but would prefer to get some input on this. Or is it only affected by local cars? If yes, only older cars, or even new ones too?
btw, if you're driving a car with coilovers, and if you're in the same boat as me, what did you do? You learned to live with or you actually attempted to fix it somehow? Would like to know about this.
Thanks.
sanekit
Dec 9, 2015
1,616
157
Thanks.
what do you mean by rattling of interior pieces? is yours set too hard? it depends on the coilovers brand, price, damping, spring rate, and setup. cheap coilovers usually are non serviceable. those higher quality ones like tein etc have better damping. you can get those serviceable local brands like HWL or PRS and get it set up properly.
i'm using those cheap taiwan coilovers. these are non serviceable so nothing much i can do about it. planning to swap these to a proper ones soon. been using it for 3 years now.
STR
155
4
18
What I meant is that, in my car, I can hear the door cards rattling and some interior panels. I'm using hwl(6k/4k) hlsh. Now I'm on the softest setting possible. So do you notice any rattling in ur car?
I had my old front abs redone, means cut open, service/change and now is serviceable. Rear are hilo only. Then friend offered me his D2 coilover which he did not want anymore since his project car cancelled. Bought them cheap but even with softest setting still hard. Live with it for a few years already since the car nowadays rarely driven, but thinking of servicing my old set and change back......lol
Reactions: STR
It depends on the fit quality of the car. I experience wira 1.6 on HWL 6k/4k hi lo...the ride is nonsense at normal pace and improve slightly at higher pace.
Does it rattle? In my friend case with his wira, it start to rattle...becomes slightly worst then stay there until today.
Reactions: STR
sanekit
Dec 9, 2015
1,616
157
my suspension is not exactly soft. haha. these taiwan coilovers i have the damping is slightly harder than stock absorber and my spring rates are 6k/4k as well. it bounce and rattle. best example driving over those new red line speed bumps at highway corners. the dash and everything else brap brap brap. :rofl::rofl:
Reactions: STR
Ever experience the glovebox auto open moment?
sweelt
Nov 6, 2016
2,306
248
name pun coilovers, comfort is second once u bough and fixed it.
i used before hwl 8k/4k , then jump to ftuned 6k/4k. I'm driving wira too.
the best u can compensate is with higher profile rubber. i run 195/55/ r15. ok lah....still got rattling , hahaha
Reactions: STR
Thanks.
It all depends on your car. If it rattles fix it. There's nothing a screw driver/spanner and cable ties can't fix. I'm currently driving around a loaner Saga FLX on hardcore coilovers and I'm absolutely in love with it. Zero rattles from the car inside and out.
Don't forget - those clicks on the coilovers 90% of the time is rebound rate - not dampening rate. Setting it to the slowest rebound rate doesn't mean it's the "softest". Just means the absorber will be slower to compress and rebound.
Reactions: STR and sanekit
Thanks.
wrong spring rate...
u need spring rate around 4-5k at front and 2.5~3k for rear....
problem solved
problem solved
Then must find something in between. My older softer suspension was better in wavy road, now harder coilover good for flat road, jumps and skip on wavy road at high speed....lol
STR
155
4
18
Yeah, exactly. Its perfectly alright for me when im driving somewhat fast. The rattling will be there when im driving slow. damn...guess ur friend is one of them who learned to live with it...
STR
155
4
18
Nah dude, im not actually looking for comfort. Knew that i cant be looking for comfort when i was getting the coilovers. Its just that, when the stuffs rattles in ur car, being a car guy, it feels somewhat frustrating. Just want things to be proper and complete in my ride. Im running the same type of tyres too. haha..
STR
155
4
18
Okay, ill give it a try. will remove the panels that rattles and fix them up as u said. yeah, no wonder ur in love with it....Got it....
okok so i had chg my airflow sensor to gsr 449 as my stock one is giving me problem
chged cz my old afs cz the check engine light doesnt go away
but probi release and press the throttle again..the car jerks...nw the check engi is after i chged...during idle the car jerks...when im crusing at 5th gear...when ne light lights up once in a while...
y is this so?ecu has been rechip frm na mapping to turbo mapping...my engine is 4g93p bot
