RPM drop and temperature drop
stutzedward
3,416
561
You will solve the problem when you increase the RPM by adjusting the setting on the throttle body, however it will be very high when engine is cold. Anyway, I had similar problems previously and it was only resolved after replacing the ICV (Idle Control Valve
Hope this post will answer some of your questions in mind.
Where is it suppose to be connected?
I had a debate with a friend of mine who question my OCT connection which I installed recently. I had connected it in between the driver side head cover outlet (PCV?) & to the manifold. Is the installation correct? I think it is if according to this post ...
