RPM drop and temperature drop
stutzedward
3,416
561
You will solve the problem when you increase the RPM by adjusting the setting on the throttle body, however it will be very high when engine is cold. Anyway, I had similar problems previously and it was only resolved after replacing the ICV (Idle Control Valve
good day mates . i have just got myself a cusco pro adjustable lsd kit . i think it is one of the latest lsd gadget they have . does any1 know whether do i need to remove the lsd itself from the car if i were to already installed it on the car , just to get the setting changed or can i just adjust it with the lsd already installed on the car ? assuming i do not need to go hardcore n re adjust the plates all over again , so by just by adjusting it easily using an allen key , i do not need to...
