Perdana v6 : Road to 300whp.... and beyond
marsha1l_v6
666
130
543
Assalammualaikum, good day and good morning..hahaha
so yesterday was dyno day. Touchup tune after rebuild internal + add failsafe + add few switches + rewiring. Reached my target whp. Below are the result. apple to apple comparison with previous dyno run @0.77 bar boost, gain around 11hp / 1.02kg torque.
so above are the result post rebuild after running in. At high boost setting, turbo out of breath at higher rpm range. Still using stock evo3 turbo. Will change to 20g ball bearing setup once turbo kong.
This rebuild setup 100% machine shop build. no forge item. stock conrod/crank but upsize on the piston size due to damage on cylinder wall caused by piston ringland crack. able to support low 400hp on wheel.
For now, no more engine upgrade. Back to handling/braking department.
Its a long journey and finally reach my target :party::rock:
marsha1l_v6
666
130
543
Congratulations on mission accomplished
thanks
thats a great well documented build. kudos to you!
thanks for going through..hope it helps in anyway to other forum members.
To sum up here few more picture
heart surgery success
sexy simple ass
New shoes!
With that new shoes, further mod on handling/traction will start next year. Now listing down mod needed to accomplish next target.
Next year target SIC under 2:50 and 201m drag under 9sec finish off with new ?? :listen:driveterrain ??
TBC next year...happy boosting :banana::burnout:
YellowFlash
308
34
Jb
thanks
sexy simple ass
New shoes!
Wow, very nice car, very nice build! Congrats on your 300whp. So far done any SIC lap before the build?
marsha1l_v6
666
130
543
Need more poweeeeeeeeeerrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr......hhahhahahahha
hahaha..maybe abit more...squeeze out few more ponies after turbo change later
Nope, not yet. Probably next year. After seeking advice from mech that maintain/handle rally car, need to buy adjustable chamber so that SIC run will be worth it.
YellowFlash
308
34
Jb
i guess you can always try out different set up at SIC, after each mod, you will be able to feel the difference in handling, in power... 300whp is pretty powerful car, next time see your perdana on the highway must faster give way :biggrin:
What tyres are you on now?
marsha1l_v6
666
130
543
Yup.. Try and error ...Hahaha
No need give way.. Urs pun 3xxwhp... My car is good sprinter . Not marathon .. Hahaha
Ps3 215/45/17 all around.. Same as before.. Thread still around 60%
For track better use extreme category....
marsha1l_v6
666
130
543
So 2019 is here....and progress slowly on going with vision "if cant afford evo, build one" . hahahaha
build theme this year alot of 4
at least 4 month car will be hibernate
all 4 wheel synchronize to be as 1
my horse breed and multiply up to 4xx
its a slow build but car should be moving around 2nd quarter of this year and complete by q4 this year. Hopefully this year definitely can drive in SIC.
some jackpot(complete set at cheapest price) catch on new year eve:
its PnP , no weld/potong needed. Just strengthen the chassis.
now need to consult otai for the gear ratio to match evo3. btw sold my link ecu probably haltech 1500/storm for DBW/low impedance injector.
Hi guys, my engine block mount bolt hole broke off. Engine is made of cast aluminium. Can this be welded back? Also which shop do i go to? Penang got recommendation?
Thanks
