What engine oil should i use for a Turbo Car ?
Should i go for semi or fully ?
  • Semi Syntium 800 10W- 40
  • Fully Syntium 3000E 5W-40
Results are only viewable after voting.
STATIC365
113
6
18
SELANGOR
Hi all ,
My Suprima S is going to achieve 1000 KM soon.
So, i want to ask Sifu here what is the best engine oil for Turbo engine ?
Should i go for Semi or Fully ?
This is my first turbo car so i will need some advice.
Thank you in advance for the assist.
Hi all ,
I just bought a Proton Suprima S and the millage is going to achieve 1000 KM soon. So, i want to ask Sifu here what is the best engine oil for Turbo engine ?
No harm going for either one just insist on NO ADDITIVE.
As per an internal buletin they released long2 time ago when the problem with oil cooler hose start to surface, they mentioned breaking down of additive molecule causes turbine failure as it clogged turbo oil feed line.
My sis Exora bold cfe has been running on semi oil until today.
STATIC365
113
6
18
SELANGOR
Because i call service center to make appointment and they insist me to use fully . Then i read online fully oil is too thin and not suitable for turbo oil. So yeah ZTH is the best place to ask for advice.
No additive, ok i will take noted. Thanks !
alcyon
800
153
543
Since your car is under warranty, then please use what SC recommend. FS is more heat resistant , and from from what I heard from my brother (works in Proton) the small oil lines can get clogged up easily if the oil cant withstand the heat, and block lubrication to the turbo.
and for the record a 5W-40 FS vs a 10-40 SS isnt too thin for the FS. Yes it is slightly thinner overall but a 40 is a 40 no matter FS or SS.
the 40 refers to a range of Viscosity at 100 C,ranges from 12.5 cst to a maximum of 16.3cst. Normally the FS will be 12.8 to 13.8 cst while the SS may be 14.5cst, so no a FS is not too thin,
Reactions: Izso
To me both can be used. More importantly is you oci and do it on time. Semi probably change at an earlier time then Fully. And like bro. alcyon mentioned used the oil recommended by your SC to follow the warranty standard...
Hi all ,
if u always drive hard or long distance high speed travel...it is better to keep the engine on fully syn oil...
petronas syntium is very good oil to use..
Reactions: gunnerzz
Hi , anybody know the exact color of te37/ssr type c white ? want to touch up the scratch myself ....but having problem to select the right paint. Any sifu here?
