DIY Fiat 600D restorodding
cant wait for it to be installed :driver:
noripsni
32
19
64
yah, I need it to make sure my fender flares are right..... like this car
The piece looks wide but on that picture of yours it looks small. I was thinking it would jut out in the front more
noripsni
32
19
64
I'm going too, I'm halfway on the front fender flares, and need the front box to finish correctly, if you look at my earlier pictures you can see I have added more metal at the front bottom, I think this grey car was built for the earlier front box with 'whiskers' and had the later wide body box fitted later............ heres one done how I like it.
Reactions: ^pomen_GTR^
noripsni
32
19
64
earlier 'whiskers' type small box, Abarth just exploited the rule book, the 600's started with small chin rads onnt e 750TC, then went to this type on the 850TC, and finally to the big wide body one for the 1000TC and 1000TCR
........ I'm building my car as a cross over model from 1000TC to 1000TCR
noripsni
32
19
64
todays work was finishing front fender flares as far as they can go without the front box as pattern, also finished welding the rear window frame and check fitted the glass.
Out of curiosity, how tall are you @noripsni ? Cuz the Fiat looks kinda small, wondering how someone your height could fit comfortably inside? Or are you going to modify the seat position too?
noripsni
32
19
64
there is loads of room in these cars........... even with stock seats, 6ft can fit easily.. on my car i have cobra classics, sitting lower and further back. 500 also has lots of space, actually better than a mini
Reactions: Izso
noripsni
32
19
64
the main issue is peddle space, as the wheel arches on both 600 and 500 intrude, so slim shoes are needed for quick driving, cheap sandles are no use
The car looks small but it does have a high roof....
Understand what you mean. I am big size myself and have driven car with closely fitted pedals before, keep stepping on 2 pedals......lol
noripsni
32
19
64
its not just high roof, the fact is there is no engine or gearbox in the front, so the front floors go way forward...... almost to the front leaf spring
Timing belt in my kancil has been squeaking for few days now. i suspected its because of the water since it had been raining recently. but the noise is very annoying. is there any solution to fix this problem?
