DIY Fiat 600D restorodding
noripsni
32
19
64
This may look a bit odd as I have yet to finish the welding under the car, but as usual, to do one thing you need to be a few steps ahead to make sure its all going to plan. so, in order to finish off the front fender welding, including the fender cuts for the 13'' rims. 175-70 tyres (period 1960's style) and abarth style straight fender flares I needed to check my ride height, that means fitting suspension that I did not have, so, the last few weeks I have been making a lowered stiffened suspension set up for the car, pictures before were with mocked up suspension, this time I had to make it for real. this involved reversing the main eye leaf, de cambering the other leaves, and fitting an 850 style cross member instead of using the soft rubber 600 clamps... here are a few pictures of the process and one of the with the car weighted with water drums to simulate kerb weight. end result was perfect ride height (stance?) with 15 mm to bump stop which can be trimmed if needed later---- the leaves were de cambered cold using an old hot rodding trick. please ignore the shitty hardware as i just used what I had to hand, new high tensile stuff will be fitted later at final assembly
noripsni
32
19
64
of course if you want to blast around and up frasers etc in a tuned up 600 at some point the weak drive shafts are going to give up, i went through a few of these cast drive cups before I got fed up changing them. so here is what a friend and I came up with, half fiat, half daihatsu, easy enough to make, I pre fabricated it all and just got a machine shop to weld and machine for me, the drive shafts are cut, machined down, then a tube is pressed on, 3 slots are then cut into the tube and into the shafts, these are then filled with weld, then the whole lot is turned on a lathe to the exac
t dimension of the oil seal boot to slip over. the drive end is made of fiat and diahatsu parts, with a custom collar fitted to join it all up. result is a super strong drive shaft that can be easily removed, and is 'fit and forget' with its tri-poid drive bathed in u/j grease.
hi mate...
keep up the good work...
i wish i was closer to your place....so i lend some helping hand on the project...
fb ruined the forums, now watsapp has ruined the fb pages, most clubs have reduced to invitation only watsapp cliques.
exactly....
noripsni
32
19
64
so today was just a paint and bondo removal day actually, but then I got the vibe on, and decided to make the drivers side abarth style flat fender flare, here's a few pics of number one and and the second one, pretty good match, and all seems to work well with the other mods.
Reactions: ^pomen_GTR^
noripsni
32
19
64
Damn! Does your friend do longshaft cutting and welding too? (Plus balancing)
nope, this was just a fiat project, plus these drive shafts only rotate at road speed, so balancing not needed
noripsni
32
19
64
What type of chemical u used to kill the rust and treat the metal?
i cut out as much as possible, but for steel that's still ok but rusting a bit i use a rust eating acid, gell type from ace is good, and general hardware got the watery type you can spray.........
Guys,
Currently run with duratec 272 cam.
However, observed engine vibrate on stock idling speed. I did tried to adjust biss to increase..but, stepper motor will compensate back after 1,2 days.
Any good method to share how to increase idling speed without flash ecu?
Pls advise... Thx
:confused:
