Airtrek Turbo subframe
biao
348
24
perak / ipoh
Hi All Sifu,
i have something need to ask and know about our Airtrek subframe (front) & (rear).
Our front subframe if want to convert to EVO, version 7 to 9 is can fix, right? if only take the EVO lower arm to fix on our original subframe, can?
did any sifu have convert the rear subframe, camber and lower arm to EVO type? if can convert, which version compatible?
stutzedward
3,416
561
I heard from Ah Wah previously that front subframe + steering rod can be installed in Airtrek improving steering response drastically. I am not sure about the rear tho.
biao
348
24
perak / ipoh
ya, the front can. but is it from evo 7-9 also compatible?
4gbanger
Jun 26, 2013
1,958
386
683
Johor/ShahAlam
front subframe from evo 789 can be fit provide complete with steering rack and driveshaft. rear im not sure as evo has AYC then need to wired the all the electronic system.. if u need LSD, just get the diff internal only and transfer to our rear diff.
biao
348
24
perak / ipoh
if just convert all the arm only without subframe, can?
because i saw the evo arm look more solid than ours airtrek.
hey guys,
i have a problem with my car.. the steering vibrates excessively from about 90km/h onwards.. i have changed new tires.. rims checked not bent, alignment and balancing done.. what else could be the cause of this? btw after doing alignment and camber alignment the vibration got stronger.. my car set up is 4agze custom made driveshaft on the left side to correct length but same spec as ori gze shaft.. right side is original gze drive shaft. bearings are relatively new.. hope someone...
