Looking for body car painting
lsm1991
1,469
185
I got my words wrong. I thought the normal white is also called metallic. What I noticed in the Gallardo is, the paint doesn't reflect as well as cars with white factory paint. It is just not that glossy.
Here's a photo of the Wira with RM6k paint. A bit difficult to notice the metal flake here.
I would be hard pressed to call that a Wira anymore....:biggrin:
RENESIS VIII
7,063
950
Ipoh
Total amount spend on that Wira far exceeds its current value... I would even say it exceeded its original factory value too.
Mod and transplanted have higher value when have right buyer. If normal standard wira then lower value....:smokin:
fazidk
413
5,183
Well if u want a good shine that last long u need:
1. A good sprayer
2. Proper/correct mixture of paint
3. Proper/correct mixture of paint n thinner
4. Good quality lacquer
5. Good quality thinner (both normal n 2k thinner) AND
6. Make sure d prep is properly done..x point spending on good quality products when d initial prep work is x up to par..but x la expect a 30k result for a 2-3k job..:biggrin:
RENESIS VIII
7,063
950
Ipoh
Slightly higher but won't be able to cover the costs spent. The paint alone is RM6k if what my friend said is true. The Brembo cost a lot too.
Since I know my Wira can't be sold for any value, might as well keep it running for the next 10 years ma. Don't want to get new car and pay installment every month. Rather fix and experiment with new things on this Wira.
Standard wira no need RM6k paint lah.......:driver:
1. A good sprayer
Correct, prep is very important. Like putty work, sanding down skill. Some paint job I have seen when you get the car looks perfect, then after a week or two the sanding lines appears and you cannot get rid of it, because it is under the paint layer....:banghead:
RENESIS VIII
7,063
950
Ipoh
1. A good sprayer
Means it depends on who is the sprayer as well? Now that is more difficult than getting good quality products.
Want something that lasts. Don't want rust problem again. Don't know what to do if main body got rust.
The roof needs replacement. My ex wira had same problem. My friend grind until bare metal on both side, means from outside and inside. Change the glue holding the sheet and frame, paint anti rust paint before respray paint and clear coat. After about 8 months started to come back.....:banghead::banghead:
Yes it is depending a lot on the workmanship too, I might even think it's more important the materials. Good materials but not coupled with good workmanship will not result good too. However normal std materials but done with good workmanship might result better.
horlow i`m confused here ....... whast the exact way of cleaning the Throttle Body ? some one teach me this way the other one say its not this way ....... show haw many ways of cleaning the Throttle Body ...... and whats the difference between the liquid and spray type
