I will change tyre soon now considering ps3 and csc5 which 1 better?
ixeo
4,788
3,080
KL, Malaysia
Depends on your car. If you have enough power it won't affect FC much. In the past I used 4 pieces AD07 on my stock Myvi 1.3. The wife loved the grip but it suffered tremendous power loss which resulted in more revs to get the car moving, meaning higher FC figures. Suffered bad. Something like 30km to 50km less than what I normally get.
But the grip was phenomenal!
this is something i observed.. i used almost botak NCT5 as a loaner while rim went in for repair.. FC was tremendously good but OMG stopping distance in wet. The road was just normal wet and it was skidding with light braking at low speeds.
whoaaaa just googled it. looks amazing. :burnout:
ZTH forum already got topic on it.....:driver:
---------- Post added at 08:53 AM ---------- 6 hour anti-bump limit - Previous post was at 08:52 AM ----------
Based on reviews I read, T1S is decent but T1R is not good.
AD08R is extreme class, cannot compare with T1 or even PS3.
Yup, T1-R did not work for my VR. Aquaplaning resistance is good, but not the grip....:rolleyes:
---------- Post added at 09:05 AM ---------- 6 hour anti-bump limit - Previous post was at 08:53 AM ----------
NCT5 problem is the sipes. New time with plenty of sipes they work pretty well. 20% worn and the sipes starts to disappear and at 40% almost gone.
Here are the visuals.....:rolleyes:
Supra_Fanatics
20,673
3,998
Some things are usually true with what you pay is what you get. My pp2 sipes till date still obvious hahaha! Damn, not promoting but fact of it being that good and long lasting xD
PP2 where got much sipes, only inside block have mah! All mostly blocks without sipes....:driver:
Supra_Fanatics
20,673
3,998
I see like many ma hahaha
Left side one not consider sipes? looks thin to me.
Ok I mean the grooves are very shallow.
Yup, the smaller side cut grooves is at an angle. The more it wear down the shorter the groove become. After about 50% most of the pattern are like straight line only.....:rolleyes:
I went to cuci mata at Brothers today.They are selling rims and tires now.
I bet most of knows PS3 reputation already.
So,when i saw 195/55/15 ps3 being sold at RM240 a piece i said 'not bad pricing in Melaka'.That is until i saw the Michelin XM2 beside it in the same size being priced at RM235.
I wonder,is it Brothers asking too much or Michelin squeezing us?
What makes it even more baffling is when i look down and saw the BS EP200 of the same size being priced at RM185 a piece.
Imho,the xm2 and ep200 have simar performance.And yes,i am using both model.
Then you ask me buy for whaaaaaaaaaaaaaaaaaatt... sommore you knew I was on RSR before changing to this Assy2!!! :mad: :thefinger:
Recently heard 16" PS3 has dropped to RM380 a piece. That's cheap wei
XM2 have always been priced closed to PS3, except one time when PS3 went up in price. Now it is back down and at par with XM2 again.
---------- Post added at 08:46 AM ---------- 6 hour anti-bump limit - Previous post was at 08:40 AM ----------
But did I say it is a bad thing? :biggrin:
All tyres after 50% wear the pattern will differ slightly from original. Whether the sipes disappear, the blocks joins up, or pattern changes pattern slightly, etc. etc....
For entry level they use harder rubber compound, so to soften the compound they cut sipes into them, that is why when the sipes disappear the tyre performance drops.
UHP have soft compound and usually no sipes or very little, that is why their handling performance usually do not drop except for in the wet after 50% and that is because the grooves becomes shallow and cannot channel water away when like new. However dry performance usually will still be there.
Hi guys ! it's urgent here.. My uncle wants to convert his perdana to VRG face .
Is this legal or what ? I know we can convert it but he's worrying about JPJ summons .
can anyone help me out :confused: thanks..
