I will change tyre soon now considering ps3 and csc5 which 1 better?
esthapo
Trail Bomber
796
186
Sister'sBedroom
CSC5P starts in 18", if not mistaken. CSC5 have 17". For you probably should try PSS instead.....:driver:
Yes bro vr2turbo CSC5P are on 19" roller...beh tahan the price & wear very fast...PSS should be more expensive i believe? thats y thought of changing to PS3 :biggrin:
CSC5P = PSS
CSC5 = PS3
Like drop one rung woh!......lol:biggrin:
Icic....so csc5 is better right?if p zero will very expansive?tyre more grip fc will higher too?
P Zero should be priced with top Conti model like CSC5. Have not checked their prices for a long time.
Well, better grip for safety too......:driver:
Depends on your car. If you have enough power it won't affect FC much. In the past I used 4 pieces AD07 on my stock Myvi 1.3. The wife loved the grip but it suffered tremendous power loss which resulted in more revs to get the car moving, meaning higher FC figures. Suffered bad. Something like 30km to 50km less than what I normally get.
But the grip was phenomenal!
That is because you jump to extreme category dy, and that usually is all out dry grip, nothing else....:biggrin:
Hi
I've recently converted to vr4 240. The question is :
If my mechanic somehow salah pasang timing belt, can it cause my car to stutter at idle (jus like using high cam)
cause my car after the conversion at low rpm stutter and idles juz like using high cam. Driving at low rpms/speed is difficult becos of this problem. Checked the injectors , plugs,cable, timing, t/body etc but still the same effect. At high rpm okay but can here "tek tek tek" sound(like the valve's sound but im not...
