Use spanner remove the whole wiper......lolI'd like to see you try to remove the wipers first But having said that you still can't have my wipers
Mine I got from Duragloss online. The other Waxco one I think good for removing Rain X only so no point.where can i get the glass polish??
But I use WAXCO Windscreen stain remover Actually smells almost the same as the PG Rain-DURA ZMine I got from Duragloss online. The other Waxco one I think good for removing Rain X only so no point.
If you are free we can try DIY on your windscreen...
All the Rain repellent smells the same. I know a chemist friend who say it is just a chemical mix. You know the formula can do also. The chemical fills the pores in the glass giving it a smoother finish that is why water beads and falls off. Cannot stick to the glass....But I use WAXCO Windscreen stain remover Actually smells almost the same as the PG Rain-DURA Z
But if stated Remove Stain from windscreen can it be use on Side Windows as well?All the Rain repellent smells the same. I know a chemist friend who say it is just a chemical mix. You know the formula can do also. The chemical fills the pores in the glass giving it a smoother finish that is why water beads and falls off. Cannot stick to the glass....
You have the Waxco Auto Clear Vision? Can use to all windows. Not sure how strong or can remove stains because stains can be anything from dropping to water marks.But if stated Remove Stain from windscreen can it be use on Side Windows as well?
No no...using this one to clean but I dun think it is strong enough though...maybe need to use a few times weekly...You have the Waxco Auto Clear Vision? Can use to all windows. Not sure how strong or can remove stains because stains can be anything from dropping to water marks.
Could be new packing for Waxco....No no...using this one to clean but I dun think it is strong enough though...maybe need to use a few times weekly...
After using that, I apply this from PermaGlass..
Yesterday use was real good but after the car is parked, when rain stop, got some mist on the windscreen. Not sure is cuz of the rain or the repellent. But swipe off with wiper then okay adiCould be new packing for Waxco....
As mentioned Rain repel stuffs I have so many brands, more or less works the same....
Mist usually happens when difference in temperature. Inside air con colder then mist outside. Like on rainy day you don't use air con got mist on the inside.....Yesterday use was real good but after the car is parked, when rain stop, got some mist on the windscreen. Not sure is cuz of the rain or the repellent. But swipe off with wiper then okay adi
But ya most important it works
