Proton Wira 4G93 Jerking Problem
CharmCheeBye
Sep 6, 2014
10
36
Hello to all forumers... Im a newbie in here and i need some help
I own a proton wira 1996 1.6cc
Last 3 week my car got problem and need to overhaul so the mechanic suggest me upgrade to 4g93 sohc... just need to change block & head..others can use back the old stuff from old engine..
About 2 week i use this car, its really nice n much more powerful compare to original engine 4g92p.. fuel consumption is great. my long run test is from Kepong > Mersing using Lekas>Kuala Pilah>Jempol>Serting>Keratong>Kuala Rompin>Mersing which about 400km and cost me RM65... For Me the fuel consumption is good
On the way back home from mersing the problem occur... My car started to jerk whenever i tried to gain more power during overtake / cruise.
I already change those things but still the problem occur :-
1- distributor
2- spark plug
3- spark plug cable
4- petrol filter
Can anyone give me a help on whats going on with my car
Thanks
1- distributor
2- spark plug
3- spark plug cable
4- petrol filter
Thanks
You mentioned you have already changed 1 to 4, means when doing the overhaul?
Spark plug problem can get that problem. Low revs no problem, high revs misfire, but can be other things also...
For outstation run, RM65 for 400km is not really that good. Roughly 12.9km/l, some mention their cars can do 12km/l in town.....:hmmmm:
CharmCheeBye
10
36
1-4 item been changed after the jerking problem exists... change those things 3 days ago...
any other factors?
** regarding fuel consumption, satisfies with it coz only about 50km highway ( LEKAS ) other than that is Jalan Kampung with lots of car and jammed
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
My Persona Auto RM77 for 350-400 town driving. lol
the distributor is replaced with a used one or recon?
i am guessing recon part.
me personally i will go for used part than recon.
it was ok after the overhaul and the swap but only happen recently...
my guess;
1.improper connection within the ignition system.
2.fuel pump
a loose battery terminal will cause jerking too.
CharmCheeBye
10
36
distributor : half cut condition...
1 : improper conection : mind to elaborate ?
2 : fuel pump : fuel pump may coz jerking too?
As i said above : original car is wira 1.6 4g92p... i transplant to 4g93 by using engine lantai ( head n block )... other use back 4g92p item... is there anything wrong with this? coz most of workshop said 4g92p > 4g93 sohc doesnt need change wiring ecu etc... only swap and change timing belt set
---------- Post added at 07:39 PM ---------- 6 hour anti-bump limit - Previous post was at 07:27 PM ----------
Which part?
If fuel pump, mentioned by bro. gunnerzz probably pressure not strong enough as you mention only jerk when at higher end when need more fuel...could be possible....
CharmCheeBye
10
36
is there anything wrong with my installation?
4g92p > 4g93sohc... engine lantai ( head + blok )... others use back original item
Maybe fuel feed in not enough as 4G92P is 1.6 and 4G93 is 1.8, and you are using back everything to run a 1.6....
CharmCheeBye
10
36
Problem Solved...The Distributor i bought from Hafkat Shop IS Already "Kapuk"
Foreman replace it with a new distributor and it solved the jerking problem
*** Additional Question : Can suggest me a suitable performance spark plug... iridium or platinum... how good it is... currently im using aerospeed cable plug...thanks
To me spark plugs don't improve performance. Iridium and platinum are just more lasting....
using 4g93NA in my wira..:slug:
will change block in near time..
so planning to do some mod along with the block changing..
heard that increase the compression will do some difference..
so the main question is:
- is it worth it for my daily driven street use only car..
- pro & con to do this mod..
- any suggestion on what piston to use & also part that must be use along with the suggested piston..
- or any other related info that i must know about this..
thanx in advance for all...
