New ride cps auto. Need some basic mod recommended ?
Sep 5, 2014
2
Hi all sifu sifu here. Newbie here. Just got my lovely neo cps last month.
Love the handling and the shape.fun car.
Currently planning to change the exhaust system . But dunno go for which extractor .
Need some advice from yours. Any suggestion???
:wavey:
C99D-MMC5537
287
78
Stock campro cps really need a good 4-2-1 extractor (this also mean removing the catalytic converter) to extract its real power. Yes, just the extractor and maintaining the rest stock exhaust system. Get a better plug cable even the bosch rm90 is enough because the stock cable really suck. Misfire at low rev-high load is common problem in stock campro cps. A good grounding cable also help a lot for this engine. Make sure have 1 cable from coil ground@body directly connecting to battery -ve terminal. A less restrictive air filter like works and knn also a good basic upgrade to do. Try this first and let me know the result. If u using manual, a 200kmh GPS top speed sure achievable (around 220kmh @ speedometer). Even a turbo preve cant catch u from pick up to top speed.
:wavey:
like another forumner said...
1.get a 4-2-1 from a reputable brand.
2.get a drop in air filter and some grounding.
u might want to change the pad to better brand as the stock will leave mark on yr disc.
Supra_Fanatics
20,673
3,998
Why not go for the readily available R3 Exhaust system from Proton? :smile:
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
Can get MSD cables from me.
Supra_Fanatics
20,673
3,998
Mod all R3 parts might as well get R3......:biggrin:
R3 one now have to find 2nd hand ones already. But not many letting go also haha!
R3 Model that time was selling close to RM80K while current one with ONLY R3 bodykit is RM61-64K.
Maybe mod cost might be close to the R3 price or they actually earn more by selling the modded parts separately :biggrin:
True also, my friend bought one last year now using for track play.
Separate sure to cost more, so instead of buying in parts, get half cut, everything there already.....:driver:
Quick question... what can affect the length and sustainability of the threads for your tires??? I used to use Falken tires for my 14" rims and they always got worn out after 8+ mths. So, this time around I decided to change my tires to Goodyear Ducaro 4 tires, hoping this'll lessen my need to change new tires every 8 mths. I don't race, I don't squeal my tires often, but I do sometimes take corners a lil bit on the fast side. Do you tink it could be cos my Falken tires were "softer"...
