wira 4g15 can use standard piston perdana v6?
rowanromano
30
2
1,508
hi bro,
u can try:
campro piston kit
s4ph - low comp piston 76mm oem spec (1.6) (willl give u 11-12bar on comp tester)
s4pe - high comp piston 76mm oem spec (1.3) (will give approx 16-18bar on comp tester) (dome piston)
or u might try
s4ph/s4pe 77mm piston
the price roughly rm350-450 including piston ring (proton part center price)
squintex
13
the car is finished already. used mazda b6 piston dome type. 78mm one. now even gear 5 can reach rpm 7k. quite an accomplishment. i decided not to use perdana v6 piston because its 78.4mm. too big for us. thx for all your help.
tofu_manic
1,342
91
5,148
interesting! never heard of that combo before
squintex
13
which combo do u mean tofu? im also interested in rowanromano post cuz i've heard ppl talking about that. too bad we already finished the car
sarutobi84
156
43
Johor Bahru
swift-turbo-malaysia.blogspot.sg
If use pv6 piston maybe can crack if abuse everyday for racing.better use fto piston 78.4 also and high comp.(got bonggol)..
last time sold my fto piston to sp4h campro guy.he say lots of campro guy doing this mode.so means wira should be a problem too....?
High compression, the will need RON 97?
78mm!!! Wah!!! Did you redo the liners? Isn't 78 already touching the water jackets?
Not necessarily la vr2, can be adjusted via ignition timing. If it's a VDO, it's automatic. Best thing is VDO will adjust based on your octane too so powerrrrrrrrr when you want it.. only bad thing is it takes about a day to self adjust.
Mine can't, and when tuned too low the power lost....:banghead:
Kyusuke_FD3S
66
1,508
lol .. it takes about a day to self adjust ...
---------- Post added at 12:36 PM ---------- 6 hour anti-bump limit - Previous post was at 12:35 PM ----------
if 4g15 mod 1.6 stroker kit, the piston remain unchange?
can i assume my engine displacement has increased from 1.5 to 1.6 ?
Stroke will increase displacement a bit. But by how much exactly depends on the crank you use, the conrods, etc. Measure it with the cylinder + oil method la. And it might just still be a 1.5++ rather than a 1.6. Since stroke is different you'll definitely feel a torque difference
Depends on the car make. If like old Ford models the 1.3 and 1.6 shares the same piston size, only that 1.6 have longer stroke to increase it's capacity. Long stroke also better low end torque.
For bro. Kyusuke_FD3S, if 1.5 and 1.6 have different piston size the stroke might be the same only...
hi guys,
I need some advise here on fixing my neo cps. i want to enable the items above and i need your recommendation on where to do it around kl and the estimated price:
1) key ring hole light (i saw the transparent ring but i wonder is the bulb in there?)
2) seat belt indicator
3) auto lock (when we step on the brake)
please assist. thank you
