What's The Difference Between RON95 and RON97
i dont think there is any difference between them as they are same and work in same manner
You mean RON95 and RON97 or between brands? If you're talking octane, then you're not quite right. Different ignition times makes a huge difference for a high compression car but you're right that they work the same, ie - they're sprayed in, it ignites and it gives the car power.
Yup, higher compression engine won't be able to run well on Ron 95....:banghead:
Depends on the state of tune though. If the engine tuning allows to use lower RON then still ok. Might not make the most max power or as fuel efficient but can still run fine as long as there's no knocking. Direct injection engines also can run with RON95 despite the very high compression.
No point if get lost of power, right?:biggrin:
Well lost just a few HP does not mean the engine cannot run well. Most probably the loss also more at the mid-upper range of the rpm so would not be that noticeable anyway during everyday normal driving. Of course this is mostly for normal every day car. If high performance cars with more aggressive tuning and especially FI engines then they would be more sensitive and might suffer more power loss or may indeed get damaged due to knocking. But if no knocking, then should still be ok.
Yup, mine knock at 4 to 4.5k rpm, until I added some additives to run RON95...
No surprise la, your car is high powered turbo monster la, cannot drink cheap stuff. :biggrin:
Have to detuned the ignition and boost a little bit maybe. My car can still tolerate the cheap stuff cause still normal level car. :biggrin:
pwhyze
924
356
1,563
True, but less aggressive tuning would render the higher compression nature of the engine useless. Might as well not bothering with high comp in the first place.
Direct injection is a different story though. The very nature of the concept means knocking is less of a problem when using lower Ron fuel with high comp engines. Wonders of (relatively :biggrin:) new technology!
Jose
243
36
Subang Jaya
Mine also experience slight knock and loss low end power when running on Ron 95. comp ratio 11.1:1
Yeah, I'm also now starting to learn about this GDi engine, cause this is the first time I own one. I do hope it will serve me well and not make me regret buying one!
The cons of GDi engine have started. Dirty inlet valves, since fuel is injected directly into combustion chamber the inlet valves are not cleaned by the fuel.
In the older technology engine where the fuel is injected into the inlet manifold just before the valves, this will clean the valves...
Everything got pros and cons....
---------- Post added at 09:47 AM ---------- 6 hour anti-bump limit - Previous post was at 09:45 AM ----------
As mentioned by bro. pwhyze, if want to detune might as well use NA. Mine is already standard low boost, if lower some more then also no point.....:biggrin:
Yeah, GDI engines need to decarbonize more often I suppose. I've done it once a few weeks ago, pretty dirty.
i just bought a rear set of TRD adjustable absorber(dark blue) from someone.
I have checked properly b4 i installed it to my car (No leaking and condition ok) but once installed, got some weird sound from the right side..like Kook Koook especially the road is rough. Anyone faced this problem b4? very headache.:mad:
