Proton Satria 1995 Roof Light problem
tingtk23
55
11
508
I think I just blown the fuse to my Satria's room/roof light/lamp =X. I was trying to DIY LED strips to light up when the door open but I forgotten to disconnect the battery. The roof light wire touched each other and it sparked. I then tried to reconnect it, but it wouldn't light up now =X. Anybody know which fuse should I be looking at? Is it under the dash board or in the engine bay? =X. It is a 1995 Proton Satria 1.6XLi model.
Under the dash. Look for a 10A fule if i'm not mistaken. Just replace any fuse that's blown there
Nov 28, 2012
2
Scranton
I think I just blown the fuse to my Satria's room/roof light/lamp =X. I was trying to DIY peimar led lights strips to light up when the door open but I forgotten to disconnect the battery. The roof light wire touched each other and it sparked. I then tried to reconnect it, but it wouldn't light up now =X. Anybody know which fuse should I be looking at? Is it under the dash board or in the engine bay? =X. It is a 1995 Proton Satria 1.6XLi model.
Apart from fuse check light bulbs are they working properly
check the bulb first... :biggrin:
tingtk23
55
11
508
Nahh, failed to find the fuse. Sent to my mechanic and he gave me a lecture for ruining the car because not only the roof light is gone, the air cond, the clock, the central lock, the radio, are all toasted too...lol
29,998
You mean all those were damaged? Usually the fuse will protect??:hmmmm:
tingtk23
55
11
508
Yeah, that is what happened... Anyway, thanks for all the replies. The problem was solved and I even had some DIY done.
hi bros and siss, i was about to change my spark plug from stock to iridium type, but i just wonder which one is better. denso has its reputation in its performance and durability, especially with its 0.4mm and it U-grooved. but wat i know about volker iridium performing good also. it has 0.5mm and can last up to 160,000km. budget wise, both is about the same. however, for Gen2, wat do u guys think? which one is better? o there is other recommendation? 1 more ques, about denso iridium POWER...
