What's The Difference Between RON95 and RON97
gOsht
Jul 2, 2011
7
503
the differ between RON 95 and 97 its not much..
only differ in RON, IBP and additive.other than that is similar spec..
if u want to feel the real power use aviation gasoline its RON 101.5 wit a far better spec
feel like using NOS..had been used in my car more than a year..
As far as I know, if you car does not require higher RON Rating, for example only need RON93 to run, then running on RON95 is good enough. Using RON97 does not give extra power. However if your car need RON97 to run then running on RON95 the engine will knock or ping....
cvkit17
2,884
1,354
It actually does give more power and a smoother ride. So many folks out there really thinks that RON97 really makes your car more powerful, have a cleaner and better engine. (Psst: even my boss who's an engineer also thinks so..oh my lady gaga)
Totally agree with vr2turbo! RON97 does not give you power itself. It is the additives that differ from RON95. If your car can run on RON95 or lower, use it. Pumping RON97 when ur car can run on RON95 is just wasting your money. Unless you want that little little extra boost to make ur ride smoother.
Dayline668
1,810
492
1,683
Ppl just dun understand the meaning of ron.... higher ron is use for better suppression for knock in high performance engine, nothing more, a stock N/A like a myvi all u get is smoother rev that's it. Waste of money...
Wanna go fast turbo or supercharge it lo...
Many think higher RON means more powerful, in fact layman terms, the higher the RON the slower the ability to burn, that is why high compression engine require higher RON. The knocking is actually denotation, means the fuel burns before compression stroke is complete. This, in the long run will damaged the engine....
Supra_Fanatics
20,673
3,998
But my saga having some knocking sound lately with Ron95 :rofl: Dunno what's the sound though :rofl:
(Mivec in disguise?)
pwhyze
924
356
1,563
Funny thing, I read a feature in a mag once, comparing different fuel grades on the same engine by dynoing the engine after each refuel. The higher RON fuel actually produce an increase of 4~5bhp...
Newer cars have knock sensors, and should readjust the timing to overcome the knock.
My old school all manual, if need to, have to manually adjust.....:hmmmm: but some mention will loose power because got to turn back the advance timing.....:banghead:
---------- Post added at 12:26 PM ---------- 6 hour anti-bump limit - Previous post was at 12:24 PM ----------
Performance engine then yes, because they require very high RON fuel....
it depends...
if stock engine was tuned to suits ron92/95 fuel with low compression setup then surely using ron103 race fuel also yielding no hp increase...
but high performance engine that was meant to use ron97 above surely got differences when using ron95/97 fuel....
even chap in Fifth Gear show acknowledge this...normal city car and boosted performance car yield different result with different fuel in the test
pwhyze
924
356
1,563
Interesting thing was, it was tested on a regular city car, an Astra or something, can't remember....definitely not high performance car with High CR. When they tested it with Ron 99 (or Ron 100, can't remember again), they got more power...so maybe Myvi can benefit from Ron 97?? XD
Supra_Fanatics
20,673
3,998
meaning to say, I have to send my BLM to mechanic to adjust? Will lose power or not? :rofl:
Dayline668
1,810
492
1,683
Not that u can feel the power increase... pointless... For RM1.1/L more if u think is worth it then is your money lo... Go pump v-power racing lo...
---------- Post added at 01:47 PM ---------- 6 hour anti-bump limit - Previous post was at 01:46 PM ----------
Less timing sure lose power n FC... What fuel u pump lately..? test with other fuel..?
BLM quite new, but not sure if it comes with knock sensor. If yes, then no need to manual adjust....
---------- Post added at 01:51 PM ---------- 6 hour anti-bump limit - Previous post was at 01:48 PM ----------
Exactly, will the power increase that much to pay extra RM1.1, even average at 45L per tank almost RM50 more per tank....:banghead:
V power Racing? that is another 30 sen premium over Ron 97, right?.....:rolleyes:
Lower the advance, will loose pick up also.....:banghead:
