4g92 sohc to 4g93 dohc..
xtremeleo
3,247
464
5,183
yes? get a 93 block and a dohc head, wallaaa.. ur current wiring can still be used iirc, just get bigger injectors, and preferably a 93 ecu
mizi0604
179
6
sorry, newbie..
would like to check and confirm if there's any possibilities to modify 4g92 sohc to 4g93 dohc??
confim can...get the 93 dohc head,piston can use back 92 sohc for more compression...wiring,buy standalone straight away~!hahaha...:smokin:
biggestunknown
4
why do i need a 93 block? can't my 92 block fit the 93 dohc heads?
i don't really get you by what you say 93 block and dohc head.. that would change my whole engine to 93 edy..
does it mean i use my 92 block with 93 dohc heads? no rebore required?
yes 93 and 92 block are compatible no matter sohc or dohc heads....
the different was at crankshaft stroke measurement and piston deck height......piston size also same for both 92 and 93 block...
Shinjite
864
120
Klang
If you change the head only to DOHC, your engine is considered a 4G92 DOHC since block untouch
If you change the block to 93 as well as the head, then only it is called a 4G93 DOHC
mizi0604
179
6
92 and 93 block use same piston size 81mm...it will consider 92 DOHC if you just change the head...if you change the block to 93,u need to endorse ur new engine block number...another way to avoid the hassle of endorsement procedure is,u can rebore ur 92 block to fit 82mm,82.5mm or 83mm piston which also can increase ur torque and hp to match the 93 block power output.
LOPI
99
4
melacca
i would like to ask can i use camshaft,valve,valve spring from 4g93 doch to 4g92 doch? tq
Hello all. Need your expert opinions / suggestions. The story goes like this, some tme back a very close fren of mine having some trouble finacially. End up maxing out his credit cards, till unable 2 pay off the debts. Resulting in being blacklisted by banks. Now few yrs downthe road, has a stable job n started 2 repay back banks. So as we know, blacklisted cant get any loans from bank, now he came across those sambung bayar / continue loan cars! Yes, touch wood so far no problem as he has...
