Help.. Myvi alarm suddenly sound..
Johnny_Tan
From Facebook
Aug 16, 2010
386
135
543
www.facebook.com
Hi all sifu.. I owned a myvi & lately i found out that my myvi original alarm sometimes sound by itself.. sometime even midnight or raining time..
Does any sifu encounter such problem.. please advise ya.. TQ very much.. :wavey::wavey:
jun_ng_1208
476
32
Cheras
Is your Myvi still under warranty from Perodua? Go give it a checking at the SC :) If not then most probably you can get it done @ acc shops ;)
adlans
138
52
How old is your battery?One of the symptom of an ageing battery.
- Just my 9 Cents, not my Nonsense -
Good feedback from the folks here and I'm going to add some more since I had the same problem
1. Send back to SC for warranty
2. Battery possibly dying
3. Door switch malfunctioning (or could be bonnet switch)
4. Indoor cabin light short circuit or malfunction (mine kept switching on by itself until I had the wiring fixed)
Johnny_Tan
From Facebook
386
135
543
www.facebook.com
HI Jun.. Tq for the suggestion.. out of warranty d.. hehe... duno should i go back to Perodua or Acc. and good acc shop in pj area??
---------- Post added at 11:17 AM ---------- 6 hour anti-bump limit - Previous post was at 11:15 AM ----------
Hi Adlans.. Thanks for the feedback.. might be.. hmm.. need to go check battery.. my battery oledi 1 yr+ d..:biggrin:
---------- Post added at 11:19 AM ---------- 6 hour anti-bump limit - Previous post was at 11:17 AM ----------
Hi Izso.. u oso facing the same problem?? hav u got it solved?? if yes.. plz share wif me which is the most possibility?? :biggrin:
I had almost the same problem. I changed the battery and fixed the in-cabin light at the same time during the warranty period so that was that.
You can test the door switch thing yourself. Press the door switch yourself and arm the car. Hold it until it goes off or release and see if the alarm goes off. Try for all 4 doors, boot and hood. Check to see if the doors close properly enough to press on the switch.
For my in-cabin light, I had it on "door" mode and it wouldn't switch on even when the door was opened so that hinted either the door switch or the sensor or circuit was broken somewhere. That one the SC settle for me.
Honestly - I wouldn't spend any money fixing the stock alarm and go invest on a good aftermarket alarm. The Myvi is so incredibly easy to steal it's no funny.
Johnny_Tan
From Facebook
386
135
543
www.facebook.com
Bro Izso.. i have to same problem like urs.. the in-cabin light also not working sometimes.. even the door is open. the lights wont on.. how much the SC charge u for tis? Hope to hear fron u soon.., Thks. :itsme:
ONEshot_3121
73
34
selangor
Bro JT, i think maybe ur myvi merajuk d:biggrin:....since cannot tahan with 'his' friend got kacing sound somemore nicely have been take care by u compare to 'her' hehe:listen: just jk oni...bro check ur battery like Izso said swap any used battery n see how...im also facing same prob with my previous ride...change battery then problem solved
p/s actually im lazy top up air battery since my car stock kilang so forgot about the maintenance..at the end battery kaput lol:banghead:
That one they changed the door switch la. Mine was done during the warranty period so I dunno how much it costs
Johnny_Tan
From Facebook
386
135
543
www.facebook.com
bro Oneshot.. hahaha.. yah lor.. i think will check 1 by 1.. battery then the door switch.. sure 1 of this cause the problem.. hahaa.. Myvi another fren oso merajuk.. battery dry coz din start for many days.. hehe..
haha. bro.. now at least got Free Maintenance battery.. more easier d.. no need top up water.. heehe.. u still using Myvi as ur 2nd car?:biggrin:
---------- Post added at 09:49 AM ---------- 6 hour anti-bump limit - Previous post was at 09:47 AM ----------
Bro Izso.. alot of help frm u.. will go to SC to check it.. Wanted to get it done once & for all or else once a while the alarm will sound .. sometimes sound midnight while sleeping.. hehehe..
ONEshot_3121
73
34
selangor
aiyoo Myvi another fren oso merajuk???cepat2 pujuk bro:biggrin: my car sold d..cannot afford to maintain 2nd car somemore my works place is not far from my house about 3km oni :driver:so drive 1 car is enough to me:biggrin:
bro hows ur car???any update??what causes??
hey guys,
i have a problem with my car.. the steering vibrates excessively from about 90km/h onwards.. i have changed new tires.. rims checked not bent, alignment and balancing done.. what else could be the cause of this? btw after doing alignment and camber alignment the vibration got stronger.. my car set up is 4agze custom made driveshaft on the left side to correct length but same spec as ori gze shaft.. right side is original gze drive shaft. bearings are relatively new.. hope someone...
